trouble connecting to DM
IRISHTY
OK. still having my problems. Bought an APU-1 from Moates. No luck. Worked with it for about a week and couldn't connect/datalog or anything else. Summer was coming so I put it away for the time being. Found my son's old laptop with Datamaster on it. So I thought i'll give it a try. I don't know wth is going on, must be the Irish luck. Can't datalog with Datamaster. Get error 0 which is no connection to ALDL/ecm. Older cable w/9pin adaptor. Know DM works/worked as there are logs from 02 on the puter. So check all my cables/connectors all tight.
So my question is..is there any readable values on the ALDL connector under the dash and if so what would the be and which pins. I tried a cheap code reader to check connectivity and it works but does DM read the same pins? I know this truck had a wiring problem at one time mayhaps that could be the problem or are my settings just screwed up?
I have 2 cables, one with USB and the other needs an adaptor. Thanks, Dan.
92TyLA
Re: trouble connecting to DM
I finally got daramaster working yesterday...im using moates extreme aldl.
Step 1 download the driver from moates http://www.moates.net/driver-download-c-78.html(since it will redirect me to another website when trying to download I followed it and clicked gm gas products, its not showing On my phone though).
2 connect the usb cable to laptop and wait for it to read it.(it will tell u wat port its at, u can then choose that port on datamas.)
3 hook up to trucks aldl and choose the port the usb is connected to and it worked for me like that.
Maybe that'll help.
WyoSyclone
Also, go to the help menu in DM and look at the section on connecting to aldl. It will give you some hints on proper settings.
