SevenT6Vet
I've posted about this before, but this is first time i have data logged it while trying to start it.
The battery is a bit weak, but it's doing the same thing it always does. Will not cold start easy, i crank it and crank it, let off, and every time i turn the key again, i get a little further. it'll fire a couple times, then crank. turn off, back on, it'll fire more, etc. eventually it will start. If it starts, it will hot start perfect.
Pump and FPR i believe are original to vehicle (91k miles).
new: plugs/wires/cap/ignition coil/fuel filter/boost solenoid. confirmed pressure holds at 43 psi and doesn't bleed down at all.
http://www.mediafire.com/file/ncvn4638wubavvu/AutoLog_002.uni
You'll notice sometimes i'll pump the gas just to see if it will help.
Thanks ahead of time for any input!
