Truck dies randomly while driving...
Gmoney
So no matter if its hot or cold outside, my Ty will randomly die, so i'll pull over try starting it and sometimes it starts back up no problem, but other times it acts like it wants to start but won't. Then there is times i will come out fire it up-run for a few seconds and die again. I just put a racetronix 340lph pump in with the harness, replaced the fuel pump relay thinking it was that, but so far have had no luck. Any ideas???
SeattleSy#1255
Category 5 Conservative
Re: Truck dies randomly while driving...
Make sure the chip is seated in the ECM...and make sure the pins in the ECM are not bent...i had only one that was bent which prevented the chip from seating in the ECM correctly...did exactly what you are describing. Proabably not it, but you may want to check it.
I agree with kessler, check the IM.
Gmoney
Before i got it to start back up, but now it won't even start. Think im gonna try the I.M. There is no power to the fuel pump either...
Fuse's?? Bad ground as mentioned? If there's a quick connect in the (new?) harness for the fuel pump somewhere check that. I've seen it where the male/female conectors didn't match exactly and one pushed the other out of the way making a poor/bad connection.
Gmoney
If it was a bad Ignition control module, would keep keep starting up after a while or would it just completely die?
Flyin Ryan
hated cuz he drives fords
They eventualy just stop working all together.
SY#2910
Banned
My SY did the same thing a while back. Would just die. Then like you said it waould start back up and run fine. I swapped out the distributor and have not had the problem scense.
Gmoney
Alright so did some tests today- when you put power to the fuel pump you can hear it clicking in there but am getting no fuel pressure. About two months ago is when I put that racetronix 340 lph fuel pump in with that whole new bigger wiring harness. Would I have to upgrade a fuel pump relay or anything else to accomodate that bigger pump and higher voltage and is that maybe why i am having these problems??
QUICK STORM
B.A.M.F. BMW Tech
check the oil pressure switch for the fuel pump, this happened to me. hope this helps!
Gmoney
I tried hooking power up to that female connector by the firewall- the one that will power the pump, but still no start... Would that be a way i could troubleshoot if the oil pressure switch is bad and therefore causing my pump not to run?
Gmoney
I emailed Racetronix and asked them what the problem could be- they said something could be wrong with the pulsator in the tank. What does the pulsator do?
jjorgensen52
NHSTE - I'm the only one!
never heard of a pulsator before... maybe thats the weird thing on my factory sending unit that i didnt reinstall....
Per the manual the FP runs for two seconds on key on. You should have instant fuel pressure at that point with very little or no pressure drop after that which would indicate a leak or a bad FPR or maybe a bad check valve at the FP? The oil pressure sw is what keeps the FP running after engine start. Also the FP should run after cranking long enough to build oil pressure.
If you’re not getting any FP at all then there’s something wrong at the FP or, like I said, maybe a bad FPR allowing all the fuel to return to the tank. On the drivers side of the fuel rail near the front is a schrader valve (under a metal cap). Remove the cap and press the valve and you should get some fuel even if only a little. If you get air then you need to find out why.
TYTILIDIE
METH HEAD
I can probably tell you exactly whats going on. I had this problem and when I dropped my tank to replace my Walbro I found a broken hose from the pump to the line. Somehow it burst. I bought SPECIAL hose for it. I think it was A/C hose but I know that it was very stout stuff. Double clamped it so well seee if it holds up. If you have no Fuel Pressure right off the bat I would say thats probably your problem. Drop that tank sonny.
Gmoney
Ya i think thats what I'm gonna have to do. Man i hate doing fuel pump stuff! Ha ha
