Slyclone
Well-known member
Got the truck going again!! Overall things are alot better this time around rather than the first.
I have small issues with a vac hose-- and a sensor but was a simple fix.
Problem this time is I review my DATA logs from about 2 mons ago when truck was running. Log indicated that the mixture was Lean. This time around I am having a RICH mixture being displayed in the Histogram in Datamaster. I have since installed a New Fuel regulator.
I am using same gauge to see where my fuel pressure is set and I have the same Low reading. 20-some psi. I had this issue before all the new stuff.
Thing is, Trucks telling me I am rich, No variance in gauge reading, I must have had this new FPR wound in pretty far and not realise it wasnt working again. Truck told me it was a Real rich mixture indicating too much fuel?
Sound like a fuel pump? I am in the process of finding a local shop whos capeable of awd dyno tuning.
Actual Symptoms : truck was struggling to come up on boost again. I think in my log I seen 3.8 psi tops
