Truck runs in closed loop only?
Doing some datamaster recording yesterday and noticed the truck runs only in closed loop. Double checked it with another professional scan tool and it confirmed that the truck only runs in closed loop. What would cause this? Thats not normal right.
________
YAMAHA FZR400
leroy
Re: Truck runs in closed loop only?
That's normal after initial warmup for the stock chip.
Jim
QUICK STORM
B.A.M.F. BMW Tech
Jim
check it when its cold to see if it switches from open to closed, and jim is right.
also, at wot above 14 psi datamaster shows 02 mv in the 150's and the ecm tries to keep adding fuel under the intergrator, like up in the 190-210 range but the professional scan tool shows 960-990 mv and the wideband shows 10.7 . The computer is always in closed loop.
________
Ford Motor Company Assembly Plant History
leroy
syclone0209 said:
even under wot
In power enrichment mode, the air fuel ratio is calculated from table F61:
0 800 1600 2400 3200 4000 4800 5600 6400
a/f 14 13.5 13 12.5 12 11.8 11.8 11.8 11.8
Or it will use the current a/f ratio, if richer. I'm assuming datamaster will continue to show closed loop.
Hope that formatting was okay.
Jim
leroy
Do you have a narrowband and a wideband?
How are you getting your wideband readings? Does it have a display, or are you logging somehow? The wideband should be grounded at the ecm for the best accuracy, if logging with datamaster. A code patch is also needed.
Jim
