M
Mike
Guest
Anybody every had a stumble in their truck at full throttle? The boost pressure seems to coincide w/ this stumble as well. I recently rebuilt the engine after a potential buyer cranked up the boost and detonated the heck out of it resulting it melted pistons and bent rods. Could the turbo have been damaged as a result of this and that be my main concern? I haven't checked my fuel pressure in a while b/c I don't have my gauge. The timing is very mysterious. When I check it w/ the advance plug out it sequentially registers 0 degrees top dead center for a few revolutions then jumps to about 4 degress. That sequence probably matches the same as when the engine is stumbling. What could be causing this?Note: no fouled plugs, plug wires checked for resistance and fine, cap/rotor good.
Thanks,
Mike
Thanks,
Mike
