Truck won't crank
cameronsclone
Trying to set this thing to tdc so I can finally start it, but i cant get it to turn over. no tick, no power loss, no nothing. Only thing is every time i hit the key the speedo jumps a quarter inch or so. Truck has power, my fans and ic pump are working. I just redid the connection for the purple wire, so that's good. Any safety lockouts that will prevent ranking? I put in walbro pump and battery relocate. all fuses seem to be good. Dead starter solenoid? it is a stocker. Anyone got a clue?
Re: Truck won't crank
Could be a distributor module. Does the tach needle flutter when trying to crank it ? I believe if it dosen't thats a sign of a bad module.
Battery relocate is a clue but before you do anything get your volt meter and see if 1) you have 12v at the starter from the bat cable and, more important, 2) with someone holding the key in start do you have 12v at the small solenoid wire at the starter?
SY756
Might try this too..Take the shifter and slam it into park fairly hard. Had that happen on my Sy a couple of times. Just wasn't fully engaugeing the switch.
NecroWolf
lost marbles member
did you put a l35/lb4 block in or did you put a newer vortec motor in? the newer motor needs a different starter. you could try jumping the starter post through the iner fender with a screw driver to see if your wiring is good up to the starter.
cameronsclone
safety switch is in check, tried it in neutral and park, took off console and checked it too. its a typhoon motor so no vortec there. I may have found it though. the connection on the starter solenoid for the purple wire looks like it was over torqued and somehow the actual threaded surface separated. I'm gonna say f it and go pick up a tahoe starter. this thing is so much dead weight an a pia to put back in.
Syclone#2960
What ever it takes!!
make sure you get a new starter ( not a rebuilt) 96 454 big block and use a heat shield on it from Mr.Gasket. The rebuilt one did not last very long.
I have heat wrap on my wires as well and even with a 3" DP those wires were as good as new when I took things apart for the rebuild. Highly recommended IMO.
cameronsclone
Well damn, that didnt fix it. This has me stumped, i have power to it, maybe i messed up some wiring to ign switch? I have the dist cap off and all the plug wires disconnected, but that wont make a difference, will it? if i check voltage to purple wire will i have to have someone holding down the switch?
cameronsclone
Looks like the prong in the relay (one that has 'c4' on it) doesnt have any voltage when cranking it. Does anyone have a diagram of what wires go to that relay? Or anyone know off the top of their head? Thanks.
SY2932
Administrator
When you redid the purple wire, how far back from the starter did you replace it? I replaced mine all the way back to the brake booster with a larger wire when I did mine. However, there are THREE purple wires in there so you have to be sure to cut the right one. The largest one of the three is the one that you want...
SY2932
Administrator
Double check to make sure that the vacuum line on the MAP sensor is connected.
cameronsclone
Hoooooly shit i am so excited right now. its 2:45AM and an hour ago i woke up my whole neighborhood, lol. Started her up, no cat or muffler as of this second, so it was an open dp. But what was louder was me screamin my lungs out at my friend from my excitement! I can't believe it, first time to run in almost a year. I couldn't bear it any longer, don't know how some of you do it with no syty for more than a year or so. I'll have to make a project thread about it once i get all my pics and vids loaded up.
