truck wont idle
Syntist
uhhh.... yeah....
my syclone wont idle, i have to two foot drive it right now. it seems like a vacuum leak? i've scanned it and i showed a AIC code but that it was working. one other thing is that it makes too much boost, it off the gauge
if yoiu gouys could help i would appreciate it.
thanks nick
JayLo
Sir Boost-a-Lot
Re: truck wont idle
I'd check all the vacuum lines for starters. Even my low mile truck had lines so brittle, they just desintegrated when I removed them.
A bad EGR can also cause poor idle characteristics. If it's open even a small amount at idle, the truck probably won't idle or will do so very poorly. Try a vacuum pump on the EGR vacuum port to make sure it's opening a closing smoothly. Maybe carbon deposits are keeping it from shutting all the way.
Hope this helps.
________
HentaiBaby
Re: truck wont idle
Have you tried pulling any codes? Also you can check the Idle Air Control (IAC) valve. If it's failed it won't idle.
Some idea's from the manual:
Vacuum leaks (as mentioned)
Too lean or too rich
Throttle body not closing
Bad EGR valve (as mentioned)
Ignition and electrical (to many to list) primarily bad grounds, just make sure all is well including the conection at the IAC.
Syntist
uhhh.... yeah....
Re: truck wont idle
yeah i scanned it, it showed somthing for the aic but it also showed it was getting the proper voltage. maybe the tip broken?
Jimmy
Banned
Re: truck wont idle
Maybe he iac is set wrong? It's simple to fix.Jumper the 2 top right ports on the ALDL.Turn the key to on (you should hear the IAC spinning.)Wait 30 seconds,then turn the key off.Remove the jumper.Pull the ECMB fuse out then put it back in.Start the truck.It should find it's own idle.
Re: truck wont idle
If we had the number(s) it would help.
Syntist
uhhh.... yeah....
Re: truck wont idle
well ok that kinda worked, now it idles at about 400rpms. i think i can hear it cycle the whole time.
JayLo
Sir Boost-a-Lot
Re: truck wont idle
What is the proper idle speed for our trucks anyway, cold and warmed up, in park and in gear?
________
Alexxa
Re: truck wont idle
But for the want af a throttle speed screw and a mixture screw...
I'm holdin' tight to get embarassed here but I believe the ECM has full control and there is no "correct" idle RPM. Somewhere between 700 and 1500 is the range I think.
Tooky
Serious about performance
Re: truck wont idle
I beleive the idle RPM at least on my truck with Ultimate chip (which I assume is similar to stock) is 625 RPM in gear and about 725-750 in Neutral/Park (both with engine at full temp). The ECM does control the idle up/down towards those targets with the IAC adjuster. There's no reason for it to idle higher than that (at full temp) unless you maybe have a decent camshaft or a bad tune/issue.. My truck idles with just a soft "woof, woof, woof" out the tailpipe. Very tame.
