Truck Won't Move!!
Inferno
Weird as hell..... trucks starts and idles fine.. Put in drive, reverse, or even try to rev in park and all she wants to do is sputter and pop out of the intake... no power nothing. I kept pushing the gas down toward the floor slowly and after about 1/2 pedal, she comes alive and will drive fine until it feels like acting up again. I have changed NOTHING on the truck since I got it.. any ideas?? If it helps, sometimes I get a check engine light for a second or two as I drive, but it doesn't stay on or scan..
jjorgensen52
NHSTE - I'm the only one!
Re: Truck Won't Move!!
Check for loose connections at the ECM and the coolant and air temp sensors, and also check for vacuum leaks near the MAP sensor
