truck wont start
93typhoon2
got spark, got 35 fp. at the rail and it cranks all vac. lines look ok. fuses ok.
anything else I need to check ? Thanks in advance.
tunerpike
Re: truck wont start
Timing? Injectors firing? I believe you need more like 42 psi of fuel pressure... I am sure someone will chime in and verify that though...
93typhoon2
is been a few months now, but It was running fine from one day to another it stop working.
do you guys thinks 35 is not enought pressure for it to start.?
Quickstop [UK]
Combating adversyty.
have you tried carb cleaner.
42lbs is stock. 35 is a bit low... if you can adjust it higher then try that - maybe you have a clogged filter or a weak pump from sitting.
If it was fine last month or whenever then it's unlikely to be compression - might still be your ignition. Have you checked for spark?
B
biggeolb
Guest
I had this problem when ever I disconnect the battery, I had to unplug the computer to reset it and it started up fine.
93typhoon2
Dave P. do you think 35 is enought to to start ? CEL what`s that ? Thanks Dave
Nacho...
berzerker
wookie
not to be a dick but your sig shows a total of four syty's owned . if you haven't got a clue how to diagnose these truck's your in the wrong hobby . cel is check engine light . which will show if ecm or memcal function is operational . try shooting some starting fluid into the air filter and then trying to start . if it catches and runs for a split second i'd guess you have a fuel delivery issue . could also be a defective battery or cables . i've seen a weak battery cause this before .
alwayscode390
pppssssshhhhhtttttttttttt
is the tach fluttering when you turn the key and rotate the engine with the starter? ---
93typhoon2
Thanks berzerker for info. I am learning about this trucks, I got my first truck about 15 yrs. ago and never had a problem with it. other than little things. My main concern was about the fuel pressure.
