Well, finally decided to try this out. I have a couple bins that I know are good... and have ran them in my truck.
I bought a moates adapter, and I think its installed correctly, but not sure if all the jumpers are in the correct location, as well as the little dial.
Anyway, its been hit and miss trying to get a bin to burn using XP. I've tried burning both 16k and 32k(doubled bin) and some work some don't.
When I get one that seems to have burned right, I take it out and through it in the zif, and the truck starts, but runs really bad and check engine comes on, then it stalls. So something isn't right.
I was told by Xtronics that if you burn a 16k bin it will automatically load it in the upper part of the chip, so no need to specify start and stop points.
So this is really irritating. If anyone is using a moates adapter, please let me know if I am doing this correctly...( if the dial has to be set to a certain #/letter when using a 256 chip) I thought that it would just be used on the 040 chip. Also I have both jumpers in the upper position.
If anyone can help, it'd be appreciated.
