trying to convert
S
surreal
Guest
I need to know what I can and cant do . I have a 95 black s-10 4.3 lit tbi can I or cant I add turbos to it need help? What do I need to do? do i have to convert it to fuel injection?
<font size=-1>[ This Message was edited by: surreal on 2002-01-22 22:36 ]</font>
BillC
In all honesty, it would probably be easier to sell your truck and buy a real Syclone or Typhoon than to convert it to turbo.
To convert, you will need: turbo, ecm, wiring harness, downpipe & exhaust, intake manifold, exhaust manifold or headers, intercooler (and cche, if going air-to-water), and various hoses, brackets and fasteners. You will also need to rebuild the motor to lower the compression ratio, if you plan to run more than 5-7 psi of boost.
If you are serious about keeping your truck and adding boost to it, you should probably look at one of the commercially-available supercharger kits. You'll still be limited to 5-7 psi of boost, but the kit should come with everything you'll need to do the install (instead of scrounging and searching for bits & pieces).
