Tune knock out?
KETCH-UP
My truck is knocking about 4 or 5 degrees with a slight increase as it gets near the top of each gear. When I hold W.O.T. into O.D. knock spikes up to 12-15. The boost pressure is holding setpoint within 1 psi the entire run. The O2 voltage is 920 on average, the MAT is only climbing by 18 degree's during a run. Anybody have this happen? Can it be tuned out somehow? Thanks!
It's just a six
Super Member
Re: Tune knock out?
Do you have a stock fuel pump? What gas do you run?
Might be good to install a water/methanol injection setup. The O2 voltage is not an accurate way to tune it.. it only gives you a rough estimate on whats going on + it is really slow acting.
Might be good to get a wideband A/F ratio meter like an LM-1 from Innovate
Goodluck!! :tup:
gjp
another post whore
Re: Tune knock out?
I got mine down to 2*-4*. I was up to 13* of kr. I went with a 160* t-stat, ngk ur6 plugs, and adj my FP. With 94 oct. gas it almost goes away.
KETCH-UP
Re: Tune knock out?
Thanks for the tips! The fuel pump is 255 Walbro. It is possibly starting to go. I thought the O2 would chop off pretty quick if pump is going? W.B and alky are on the "to get" list .I tried the 160 thermostat a couple times, and my truck stumbles at low to mid range each attempt. I am stuck with 180. Havent tried UR-6 plugs yet, but will this week.How much quicker is a W.B., I thought they were just linear over some range, I did not know they are also quicker!
Re: Tune knock out?
12-15 is a quick way to be investing in a new motor.
It's just a six
Super Member
Re: Tune knock out?
The wide bands are almost instant response.
The stock O2 sensor works fine in my Sy ....but it is no where close to what my LM1 reads.
Six-is-Enough
Use to do a little Boost
Re: Tune knock out?
You might want to try the NGK Iridums if you are not using alky. They seem to do even better with knock retard, but you can't re-gap. URI6 is the ngk #:tup: .
KETCH-UP
Re: Tune knock out?
Thanks again for the help and advice. I tried the UR6 plugs for the first time and really noticed a big difference . The idle was smoother than ever, and the truck started quicker just bumping the key! The knock reduced to 1-3 range on 94 octane 16psi setting. Still getting a little more knock if I stay in it to OD. The info I posted before is slightly wrong, as the knock peaks right at the shifts. A 2 PSI increase in fuel pressure got me down to 0-2 on knock. I added a MSD-6 and could not see any difference in any data? I added 2 gallons of toluene to half tank of 94 and turned boost up to 20PSI . Knock stayed in the 0-3 range on a test run. Let the truck cool down, and iced the IC to get a good data run. Did a nice take off with no power braking, and over rev just a little in first gear~5500 RPM and going into 2nd.. crunch, clang out goes the tranny! Why does the fun get ruined like this? These things are evil!
