Tune up- stock ty
Espritmike
I just got my '92 last weekend. It had no power so I had all new cats and exhaust put on it yesterday (I own an auto shop, so 2.5" cat . magnaflow muffler and all new piping was $200.. Lat night I reset timing to 0 (was about 2-3 deg retarded). fixed a small vac leak at front of intake plennum, and replaced fuel filter (was rattling internally). Now it does acually have a decent amout of pull, but sputters bad under full throttle and high boost. I want to replace cap rotor, wires and plug, but want recommendations on which plugs to use. I've heard NGK UR6 and Autolite 63's. Is that a preference? Gap (iv'e heard .025-.028). I also may check into replacing fuel pump (will verify first fuel pressure and if it is going lean at O2). Truck has 162k on it. Thanks Mike
GM TURBO
Sell Out
Re: Tune up- stock ty
Stumbles are 99% of the time ignition related on a stock truck.
NGK UR5 stock heat range
NGK UR6 colder
ACDelco CR42TS stock
Don't run Rapidfire (speaking from personal experience). Also I wouldn't use the CR43TS. I ran the UR5 and liked them more than the Delco plug as they helped smooth out the idle.
For C&R run one with brass inserts - not aluminum.
Taylor wires
I use the Acdelco CR42TS or CR43TS. I would keep the gap at .03 unless you are running high boost. It seems to like the larger gap for driveablility. If its sputtering you have not seen anything yet. It does not take much for these things to slow way down over any little thing.
Espritmike
NGK UR6 colder
Taylor wires
Being a mechanic for 20 years the only plugs I have ever had a probln were Rapidfire, Bosch single platinum and champion. I'll never use any of those plugs in anything. I think I'll try the NGK's Iv;e always had good luck with them. Thanks Mike
