Osmosis
I have an old..Very OLD IBM think pad 233 that currenlty runs my tuner pro with no issues. I also have a new ibm thinkpad. I have the andrew mattie adapter cable that has a db9 connector to connect tuner pro to my old laptop. I purchased a usb adapter for the cable from radio shack, I installed the dirver on my new laptop for the usb cable. Consequenlty, I can not connect to my ecm with my new laptop via tuner pro? I have changed the com port on the aldl settings in tuner pro under preferaces. Sometimes, I get the cable to connect under the preferaces, however, I never get the cable to connect to the ecm.
I know it has to be an issue with the usb driver/port as the cable works great with my old laptop. I just would like my new laptop to connect to tuner pro as the battery last 3hrs longer than my old computer. Can anyone help me?
I installed the driver from moates.net and with my pc not connected to my ecm, the cable show's it's working fine under the aldl preferances @ com4. I then connect the cable to my ecm, no connectivity? WTH??? Then, I try to connect to the com port through the preferances on the aldl cable, nothing? I switch to com 3, it connects once, and then does not connect???? HELP!
Thanks for the help!
