Tuner pro RT and scanmaster 3
QWK STRM
1889 92Ty
I currently have scanmaster 3 with tuner pro rt and a TT velocity chip. I just got the program linked to the scanmaster. I have only seen data master TT work to make changes to the chip seems easy. But how do I see the changes and current peramitors of the chip through the tuner pro rt. Tuner pro seems a little more complicated right after I got it linked we got 5" of snow so will be a bit to log data on this. Here is my data master log.
QWK STRM
1889 92Ty
Re: Tuner pro RT and scanmaster 3
I have all that info I just want to see what page and where on the tuner pro I can see the parameters and changes.
Eric Sy GN
You need to be able to see the INT (which is Sterm on DM) and the BLM (Lterm on DM).
You can see those on the Data Lists when monitoring in TunerproRT.
You could also display the Dash, then right-click on one of the numerical displays, and change it to INT or BLM.
Here is an example of the Velosyty Dash on TunerproRT showing where I changed it to show INT and BLM.
QWK STRM
1889 92Ty
Ok thanks Eric but where dies it show the numbers 1-7 while the gas pedal is down?
ChiPhoon
Chicago Typhoon!
snow is all gone on the road and most if not all be gone by end of tomorrow, so go log! :)
QWK STRM
1889 92Ty
So Eric I got everything working except I can't access the chip with the gas pedal. Any suggestions? Yes time to start data logging when the salt clears.
Eric Sy GN
Accessing the adjustable parameters is completely based on the throttle position sensor. A bad sensor might cause some issues. Or maybe you are not performing the procedure just right.
If you want, make a recording of you trying the procedure and send it to me.
Eric
QWK STRM
1889 92Ty
Ok I am getting 100% tps key on push 3 times in less than 3 sec and holding the 3rd time. And the int shows 0. Sow once key is off the data link takes a few seconds as well for the scanmaster to boot up.
