TunerPro 4.14.0369 out
skwayb
NWSTP
Fixes cable detection routine so it should find your ALDL cable now. Download it at http://www.tunerpro.net/downloadApp.htm or use the check for software update in TunerPro.
v4.14.0369 (10/21/07)
TunerPro Free & TunerPro RT
Fixed bug in Download RAM to file - now saves to correct file path when inputted by hand
Fixed bug in Download RAM to file - when complete, it no longer stalls on "Writing to file..."
Fixed rendering bug in 3D graph when table axes are defined from high to low
Slightly optimized table (grid control) rendering
Fixed issue with ALDL cable detection in ALDL/Emu preferences tab
v4.14.0365 (9/21/07)
Full support for Moates RoadRunner, for those who can make use
v4.14.0362 (8/29/07)
Fixed a crashing issue when importing certain definitions
Fixed bank switching problem with Ostrich/Ostrich 2.0
Fixed Roadrunner encryption routine (more work to be done there, though)
sytyguy
Moderated User
Re: TunerPro 4.14.0369 out
On this note, does anyone have issues with detecting hardware (even with the new release)? Sometimes if I have the autoprom already plugged in (and recognized by the OS) TunerPro will lockup on detection. If I start up TP and then plug in the autoprom, sometimes it'll still lockup upon detection. Doesn't matter how I handle the physical intialization (before or after TP startup) or software recognition (auto at startup or manual), it still acts flaky. Sometimes it'll find it immediately, sometimes it won't.
I realize this is a question better left for Mark, but I thought I'd ask if anyone here had issues so as to determine if it's my machine/autoprom.
No other issues with hot P&P'ing any other USB device.....and Windows recognizes the autoprom perfectly.
Hood
ashman
i have similar detection issues with my ostrich. most of the time, i'll have to unplug and replug the device to have it recognized by TP.
another note...the latest version of TP requires admin rights for installation.
skwayb
NWSTP
Hood
I had that exact problem when I had an older Bios version of the Autoprom. Make sure you have the latest one flashed to the Autoprom. One of his version fixes the upload speed so it is lightning fast. Once I upgraded the BIOs for the Autoprom, the problem of not finding the hardware went away.
I have ran into a problem with both the Autoprom and Ostrich where it will lock up on detecting hardware. This happens when you keep putting the Autoprom or Ostrich into a different USB port. It can be worse on the bluetooth version since TunerPro will look through all 255 COM ports now. So it may look like it is locked up. To get around this problem, I make sure I plug the Autoprom into the same USB port everytime, I make sure XP sees the port and then I boot up TunerPro. If I am not using the bluetooth, I make sure to have the bluetooth software I am using isn't running. Then TunerPro will usually boot up really quick and not hang. If it looks like it hung, then just let it sit for a coupel of minutes, it will eventually open up. Sometimes I still need to reboot the computer to fix it if it never opens. Mark is trying to figure out why it does that but hasn't found the problem.
Now if you are running Vista on your laptop then that could be another issue. In XP it works. ME forget about it (Mark doesn't even support it) and Win98 TunerPro runs pretty good.
Ian Turgeon
Cascading Inspiration
Just FYI, amazingly TunerPro works on my Mac, running XP virtualized in parallels. Connecting to the Autoprom even seems to work flawlessly. Its one of those things I wasn't expecting to just work.
sytyguy
Moderated User
Turned out to be the firmware of the AutoProm (well that or the upgraded USB drivers from Craig) that fixed it. Updated those two and all problems seem gone now.
Makes sense as I have the 2nd AutoProm he sold and I had yet to update it.....doh!
Hood
4C FED
Absolutum Dominium
I tried the update in TunerPro & could not get it to update.
I have the full registered version TunerPro RT, if I download & install the new version will I have to register it again?
ashman
just make sure you save you .tpk file. that is your registration file. after you install, just drop that file back into the program directory.
4C FED
Absolutum Dominium
OK, thanks.
Tooky
Serious about performance
I just upgraded and still have some of the same problems I've been plagued with forever. Whenever I contact Mark Mansur he says he can't reproduce these problems, but I have it on EVERY PC I load TunerPro (at least 4 completely different computers, Win2K & WinXP). My problems include:
- random program crashing when making changes and opening new tables
- program freezing via runaway CPU usage (100%) when clicking "View Graph" on a table
- "Window" menu tracks all open windows for the first 3 or so windows opened, then doesn't track any further windows at all. So you'll have about 10 windows open and you can never use the Windows menu to actually find them because this bug prevents them from being listed. I just tested and verified this bug still present in 4.14.0371.
- when doing real time emulation changing fuel tables, 99% of the time you need to re-upload the entire BIN for the changes to actually take effect (even though TunerPro claims the updates are made when you click Update and it beeps success). Very frustrating when you "think" you made a change and TunerPro confirms it, but it didn't "really" happen yet.
Signed,
Registered TunerPro User
4C FED
Absolutum Dominium
I used mine yesterday to calibrate my gauges after installing the new faces.
How in the heck do you resize the dashboard? It is squished down at the bottom and I can't read the values.
I finally switched to the list view so I could see what I needed, but I'd still like to resize the table.
ashman
do you have some other software installed (that would be common to the other computers you've tried) that could be causing the problems?
sytyguy
Moderated User
Agreed.....Try this: Windows Key + R will open the run command and type in msconfig. Once open, click the startup tab and uncheck any unneeded programs. Most laptops will have a program for the touchpad and possibly audio and video control panels. You can leave these, but the hardware will still work if you disable them in most cases. I'd disable all and restart.
If this fixes the problem, you've got a software conflict issue. Possible something trying to take command of the particular USB port your using with TP or trying to restrict TP from having access altogether (protection program of some sort possibly).
You can then go back and recheck the programs you need (do a few at a time) and restart. Continue until the problem resurfaces or you're content with the startup settings.
Hood
Tooky
No, definitely not. I'm certain it's a program malfunction; I used to write Windows software and I did a little debugging to see where TunerPro was failing. I'm just surprised to hear that nobody else is having the same problems I am. I bet I could visit any computer in person and install TunerPro and get it to reproduce my problem, though. :lol:
