skwayb
NWSTP
I finally got around to getting the files into a release form. These are still a work in progress but you should be able to connect and play with the new dashboards, history, monitors, etc.
Also I put a MPG calc in the ADX file. For you to use it, you will need to change the Injector Constant in the ADX. It is a rough estimate but it works fairly well.
If you come up with something you would like to see as a dashboard, history, monitors, etc, post them. We would like to add what you guys want to see and would use into the ADX file.
You can get the files here. (you need to be registered on Code59 to download the files)
Code 59 TP5 Files
Code 59 TP5 Files
