TunerPro boost question
Is there a way to tune the wastegate duty cycle vs. MPH and not have it change the duty cycle vs. throttle position? When I change one table the other changes as well.
I am trying to limit the boost at lower throttle positions. When I am driving normal the boost tends to surge when going up hills and when under any load. I'm trying to limit the boost surge a little by lowering the wastegate duty cycle at lower TPS. I tried doing this using the boost vs. TPS but that table also changes the Boost vs. MPH table just like the WG Duty cycle tables.
I'm kind of new at this stuff so if it's a stupid question then you know why.
Alan
Re: TunerPro boost question
If your using code59 then it is a switch. The 2 tables are shown and will change with each other, but only the one that is turned on via the switch is active. (actually they are the same table the ecm just uses MPH vs TPS sensor and due to having to label it for each setup we have the table duplicated)
Basically ignore the TPS one if you have it setup for vs MPH
turbodig
They are one and the same table. As Jeff said, once you've selected the MPH flag, you're using the MPH index, otherwise, it's the TPS index.
You can set the flag back to TPS if you like. Keep in mind, a stock turbo will make 8-12 psi at 0 DC....
tough to prevent a stock turbo from making boost.
As dig said, as a test for a lot of people on here that tend to blame the ecm logic set your WG DC to 0's and make a pass, if you overboost no controller in the world will fix it.
I am using code 59. My turbo is a Waller 20g. I can get the wastegate to do its job but I thing im just having a rookie tuning problem. I have great boost control when WOT just not so good when normal driving. If I am accelerating ( just a little like a normal drive) up a hill at 50% throttle the boost seems to shoot up to 20+ psi.I want to try and limit my part throttle boost to 8 to 10psi.
sytyguy
Moderated User
Post a screenshot of your F70 & F71 tables. Once I have a WG dialed in, I usually go into F71 and "ramp" the boost towards the final boost level I want. For instance, I might have DC increasing by 5 per cell up to a final value of 65 DC for 75% and greater. Something like that. Just depends on the truck and it's setup.
gnnorthwest
PNW SyTy Headquarters
Sounds like it could be a bit aggressive on the closed loop correction - might want to check to make sure that's not messing with you.
