Tunerpro bubble has been released.
New syty def. files can be gotten here.
www.nwstp.com/rev5.zip
Paul and I will update nwstp with final versions in day or so.
Taken from Marks post on www.thirdgen.org
[font=Verdana, Arial]Hey fellas -
I've just uploaded version 4.12 of TunerPro and TunerPro RT. There are a ton of new features this time around. Here's the shorter list:
[/font]
Some screenshots (click to enlarge):
[/font] [font=Verdana, Arial]
[/font][font=Verdana, Arial]
[/font]
[font=Verdana, Arial]Typical TunerPro WorkSpace[/font]
[/font]
[font=Verdana, Arial]2D Graphing[/font]
[/font]
[font=Verdana, Arial]3D Graphing[/font]
Enjoy, and as usual, please let me know if you have any issues with the software. I'm sure you will this time around, as there's lots of new stuff (which means new and interesting bugs)!
You can download these versions at:
http://tunerpro.markmansur.com/
As always, TunerPro Free is completely free and is nag free and feature complete. TunerPro RT is still free, but you must endure a nag screen at startup for a few seconds (simple motivation to register). Registration for TunerPro RT is $30 USD and is completely optional. The unregistered version is feature complete and will not expire. =)
Mark[/font]
[/font]
[font=Verdana, Arial]TunerPro Free[/font]
- [font=Verdana, Arial]Brand new 2D graphing control with the following features:[/font]
- [font=Verdana, Arial] No more aspect ratio distortion or strange resize zoom[/font]
- [font=Verdana, Arial] Auto-Range (in preferences)[/font]
- [font=Verdana, Arial] Ford-type function graphing (drag X and Y axes)[/font]
- [font=Verdana, Arial] Multi-selection (Ctrl + Click or mouse drag)[/font]
- [font=Verdana, Arial] True axis valuation (negative numbers show to-left or below Y and X axes respectively)[/font]
- [font=Verdana, Arial] Z Axis auto-labeling based on window size[/font]
- [font=Verdana, Arial] Brand new 3D graphing control with the following features:
[/font]
- [font=Verdana, Arial]Surface shading (wireframe mode still available in preferences)[/font]
- [font=Verdana, Arial] Axis labels (All axes)[/font]
- [font=Verdana, Arial] Linear zoom based on window size[/font]
- [font=Verdana, Arial] Z Axis auto-label based on window size[/font]
- [font=Verdana, Arial] Axis label auto-hide based on axis length for readability[/font]
- [font=Verdana, Arial] 3D Table smoothing (in Table Editor Toolbox) - specify a modifier of 0.0 - 0.99, select a region at least 3 x 3, and hit Execute![/font]
- [font=Verdana, Arial]Visibility Levels and Categories for items (set for each item). Items shown based on globally selected visibility range and category combinations
[/font]
[font=Verdana, Arial]TunerPro RT[/font]
- [font=Verdana, Arial]ALDL Data Tracing[/font]
- [font=Verdana, Arial]Link an XDF to an ADS[/font]
- [font=Verdana, Arial] Link XDF Items to ADS Items[/font]
- [font=Verdana, Arial] Playback Log or actively monitor ALDL stream and see visual feedback on where the engine is running in a constant or table.[/font]
- [font=Verdana, Arial] Fixed issue with ALDL cable test[/font]
- [font=Verdana, Arial] Smart hardware detection - checks the last port known to have hardware detected first[/font]
- [font=Verdana, Arial] Fixes simultaneous 160 baud datalogging and emulation for AutoProm users (requires AutoProm firmware v2.13.A)[/font]
[/font][font=Verdana, Arial]Typical TunerPro WorkSpace[/font]
[/font][font=Verdana, Arial]2D Graphing[/font]
[/font][font=Verdana, Arial]3D Graphing[/font]
Mark[/font]
