tunerpro help
littleblackpsycho
I just got tunerpro and am doing the initial startup the only thing is I've got 50 lbers, a three bar map, 20g, open downpipe, air to air, no egr, and ac delete. The only bin I could get was a stocker so is there some things I should do first before I even start trying to do the f29c tables? Also should I disable the egr, ic stuff, and all the ac stuff? Thanks
cvcsmkr
Re: tunerpro help
ask around for a 50#, 3 bar file.
i am pretty sure there is quite a bit of work just to get the bin working for the injectors and map. i ve got one or 2 i can send them to you later tonight if someone cant get you one in the mean time.
