Tunerpro Rt bubble ??
MRKING
New Parts for Old Trucks
I have tunerpro rt working and have downloaded the newest .xdf and .ads files , but the bubble isnt working . I have the data tracing activated , and can emulate and record , but for some reason it doesnt show the corrosponding cell data in real time like desired . I have both downloaded files in the same folder . I also went to the xdf header editor and under aldl association , I linked the .ads file to the .xdf , but no bubble .
I am at our Memorial Day F.A.S.T. meet right now at Ians parents house, and a couple trucks are needing some help .Can anyone tell me where I went wrong .
SBNova
Re: Tunerpro Rt bubble ??
Did you define the X and Y, under association? My datatracing works fine. I am planning to come tomorrow and I will try to bring my laptop w/ Tunerpro RT, autoprom, wideband O2, and my Belltech G-meter.
MRKING
I didnt do that . We are leaving right now , but tyson is coming back tommarrow , and could you show him so I can get it sqaured away . I will mess with it on the way home and see what I can find . Thanks . Sorry i couldnt do the 2 day thing and get to meet you .Later.
SBNova
Hey sorry I couldnt make it on Saturday. I had to work and missed out on the main day of the event.
Try this link and see if you can piece together the data tracing;
http://www.thirdgen.org/techboard/diy-prom/361313-tunerpro-rt-aldl-data.html
I had to go over this info a few times before it finally sunk in. Like I posted, I still have the problem with the tracing in the spark table. I havent had time to email mangus the files he requested to fix the problem.
MRKING
I will play with it monday , but I finally think I understand it all now . Each table that I want the bubble in , must have the x and y axis's linked . I at first thought that only one table had to be done , and it would show for each . But after more messing around , I saw it wasnt that way . Thanks for the link . I was registered on that forum already but didnt think to search there .
MRKING
Alright , another question . I tried linking the tables , but it doesnt highlight the "select x axis aldl item" box when clicking each one . It only gives me the option to link them if I click :
Fueling
Spark/Timing
Acceleration
Deceleration
Boost Control
Tcc
Idle
Egr
Cold Start/Run
Other
I wasnt sure if they all were X=map 3bar , and Y=rpm .Do I need to link all the ones above ? From reading I have seen that I should change the output types to Integer from Floating type , but say I do that in the Fueling aldl assoc , do I have to change the same output types in the actual F31e,F29,F30,F28,F31m,F31,F77,F92,F94 tables as well ?
skwayb
NWSTP
Just redownload both the XDF and the ADS file off NWSTP. I have everything linked unless the new files I put up there lost their linking. I also added all the F table numbers and went through the ADS file again. Everything should be working. If not let me know and I will fix it.
SBNova
So the XDF and ADS are updated again? I just wanted to clarify, as you said re-downloaded, not uploaded. On a side note, for datatracing to work for me, I have to redefine all the association stuff almost every time I use it. When I pull it up, the correct info is highlighted but not selected. I dont understand why, buts its happened a few times.
skwayb
NWSTP
I am tweaking both files when I find errors. I think the ADS file is pretty much done unless someone finds an error in it.
As far as the XDF goes, I keep finding things there weren't correct in the XDF I started off with. So I correct them as I go. I know RBob has one up on Moates.net and it gets rev'd from time to time. His is a 2bar XDF and mine is more for 3bar.
I will probably have an updated XDF done by next week. I am helping test the new code and I am resposible for botht the XDF and ADS files for it. So I am in the process of going through the entire XDF to make sure everything is accurate.
In the meantime, I would redownload the files that are up on nwstp and make sure you have both files in the same folder. They should be linked properly. I didn't link every table in there as they all aren't necessary to have linked up. If the linking isn't working or you see a table that you think should be linked so the bubble works, let me know and I will correct/add it.
MRKING
My blown msd box has me now chasing ignition problems , but I should have the tracing working with the links I made . A newer .xdf would help though incase I didnt get everyone needed . I appreciate the hard work you have done to get everyone this far . I dont know when mark has the new version coming out , but this version is pretty damn sweet as it is .
