qbnkiller
Conflaguration Specialist
...well.....
I bought the emulator (G1/Ostrich) and have Tunerpro RT. Installed the drivers, upgraded the firmware on the Ostrich. I have it connected correctly (the stock chip is installed with the single notch pointing upwards in the adaptor, and the ribbon cable is indexed on the Ostrich box and the red wire is on the left-hand side facing you). I put all that crap in, turn KEY ON ENGINE OFF, setup the COM PORT (tried 1,4 and COM 5). I setup in TunerPRO RT the COM port and when I try to connect through ALDL, I get instantly a connection error, similar to if I didnt have the USB cable attached to the laptop/Ostrich.
Any suggestions? Trying to get the truck programmed for S-Series...running out of time.....
Thanks for helping,
Alex
Thanks for helping,
Alex
