Tuners please help
wildphil
I Love My Ty's
I have a few questions.
Tune is pretty good. There is one problem with the tune. As I accelerate there are a couple of lean spots. The cells I am hitting are lean under acceleration but AFR is right on when cruising and on these cells.
Would I adjust F38? If so How much? If not any suggestions on how to clear this up.
TYTILIDIE
METH HEAD
Re: Tuners please help
I have fought this battle in every truck I have tuned so far. It is a PITA and pretty obnoxious. I had a thought once but no one seemed to think it would work, to up the time acceleration enrichment is enabled and then adjust the table accordingly. Accel enlean is only on for a split second. I figured, why not make it last for saaaay, 1-2 seconds, about the amount of time you see that lean spot and simply adjust the table like I said. I should just try it and see what happens.
Peter
my Ty and me 25+ years
I accidentally discovered there is a delay of one or two data recordings between the time TunerPro highlights a cell and the time the WB O2 sensor responds, especially under acceleration. Try adding some fuel on the cell or two it hits just before showing lean. The trace passes through cells rather quickly as the RPM's and boost shoot up. I'm a little surprised you're actually hitting the same bins in accel as cruise. Shouldn't the accel bins be at higher MAP and RPM?
I imagine that delay is the time from once the combustion stroke happens to one revolution of the motor (exhaust stroke) then time for the exhaust to go through the exhaust manifolds and turbo. Their may be a slight delay in the WBO2 to acquire data and their would be slight delay in the WBO2 AD converter in the ECM and a ECM processing delay. All that happen quickly but 1 Tuner Data frame is only ~.15 sec. 3000rpm is .02 sec for a revolution. .1 hundred here and there, it makes sense that you might see 1 or 2 frame delay. Also remember that 2 frame delay could be a reaction that happens .16 apart from the event (assuming the frame if exactly 0.15 ) if the event happen just before a frame ended.
TYTILIDIE
METH HEAD
That could be the issue however I have seen it almost always where once you are complete in you acceleration and the cell is no longer changing you still are in this lean spot that takes 2 seconds sometimes three to stabilize. There is no way in hell data stream is 2 or 3 seconds behind. If that was the case tuning would be almost a guess and next to pointless.
wildphil
I Love My Ty's
I didn't give enough info about this.
This only happens under normal driving. Like from a stop accelerating normally.
During hard acceleration it does not happen The AFR is fine.
BMFB
Not to scale
I actually have the same sort of issue with gentle acceleration, and I'm not sure what to do about it, mild accel it goes away, but my cruising cells and my gental accel cells will sometimes overlap, as of now I just deal with it, cause I dont really care about gentle accel being perfect if its gonna effect my cruise MPG. I'm sure theres a table for this that I just dont know about.
wildphil
I Love My Ty's
I read it right and understood, that is exactly what I was talking about.
Ok Mike. I wasn't sure everyone did after I reread my post.
And were Peter had answered wondering how I was hitting the same cells while cruising and also at times when accelerating.
I sometimes don't word things very well.
WyoSyclone
I assume you're still running open loop... can you email me the BIN and a log tomorrow? I've got some down time so I can work on it a while.
BoostedSUV
Kind of sounds like what my truck was doing... Light acceleration and it would hit rpm specific lean spots. Hard acceleration or WOT it was fine.. I really hope you aren't battling what I battled with. I finally gave up and started a new project.
wildphil
I Love My Ty's
It looks like this is a common problem. If someone can find the cure it would sure benefit a lot of us.
I sent those files to you Rob. Thanks for looking at them for me.
WyoSyclone
BIN returned with some changes... let's see how much it helps.
TYTILIDIE
METH HEAD
Let us know what happens. I have tried everything and if what Rob does for you works I'd love to hear the fix.
wildphil
I Love My Ty's
Had storms here today. So I didn't get to check it out today. Will try to tomarrow.
TYTILIDIE
METH HEAD
I tried my idea this evening. Didn't go anything like I thought it would. I may take another crack at it tomorrow. Mine is frustrating as hell, I get clear in to the 17's, hold the pedal in one place and suddenly all by itself, it goes back to 14.7. I don't know what else to do. I may try making PE come on with less TPS and take some fuel out. Just a thought.
BMFB
Not to scale
For that its more about the adjacent cells, not the cell your on...as far as my understanding goes your never on just 1 cell, but 4 at a time. It interpolates the data and comes up with an average based on a percentage of each adjacent cell. try messing a bit with the cells directly adjacent to where you are. Just an idea, but I've had that happen, I notice it most with a loopy idle. it will be kinda rich and idle up, then hit a leaner cell and bog back down, then loop.
