tuning and WB02
TYGUY
i have searched this board for information on tuning and WB02 stuff. i can t seem to find any SOLID info on what to use.
i was going to use my laptop and a WB02 set up to try and tune my truck, can i do this with an ultimate and a WB02 set up?
Dustin
Maxtor
Re: tuning and WB02
Yes. If you are planning on doing your own tuning with the stock ECM, you will need some other equipment in addition to the WB. Datamaster is critical to datalog your runs and provide feedback on what to tune. The output from most of the common WB sensors can be hooked into the ECM to datalog with datamaster in the "AFR Target" position with a code hack that is widely available from a board member. Once you decipher the data you have collected and are ready to make changes to the lookup tables, you will need some type of tuning software (promgrammer, tunercat, or tunerpro) and the ability to burn chips. You can also buy a romulator and do on the fly tuning in place of chip buring.
In summary, you have a lot to learn. Nearly all of this information is in the archives on this board. It won't happen overnight but if you are persistent and do the research, then ask specific questions when you get stumped, you will learn how to tune your own truck and add to the enjoyment of your hobby. If you decide it is too much work (and it is a lot of work), there are people on the board who can tune chips for you.
Good luck.
TYGUY
Re: tuning and WB02
thanks for the info. sounds like i am on the correct track, i have orderd my Datamaster cable and stuff..when i see how that works i will move onto choosing the correct WBo2 to go with it....thanks again
JayLo
Sir Boost-a-Lot
Re: tuning and WB02
It's just a six said:
I use the LM1 to tune my truck.
Very nice unit.
http://www.innovatemotorsports.com/
The LM-1 rocks. It's very easy to use too. I have the tail pipe attachement so it can easily be swapped from car to car.
For my Syclone, I also bought an LC-1.
http://www.innovatemotorsports.com/products/lc1.php
It's basically an LM-1 without the handheld display. You can connect this directly to a laptop to datalog AF. The thing I really like about it is, since it can output both wide and narrow band signals, you can use it to replace the stock narrowband O2 all together.
________
NATURAL REMEDIES CAREGIVER VALLEY VILLAGE
ashman
Re: tuning and WB02
you might also spend some time at thirdgen.org board. they have an ENORMOUS amount of info and alot of it applies to our trucks.
Flyin Ryan
hated cuz he drives fords
Re: tuning and WB02
How do you like the LC-1? does it get the job done? how's it connect to the lap top serial, usb?
JayLo
Sir Boost-a-Lot
Re: tuning and WB02
It uses a serial connection for a laptop, but to be honest, I haven't used it yet. We are currently installing it where my cat used to be for use with my MegaSquirt EMS.
MS will use the wideband portion of the LC-1 to control fuel while the narrowband signal will be used for my AF ratio gauge. I've been told this will turn an otherwise useless narrowband AF gauge into a pretty accurate warning device. A guy could just as easily use this narrowband signal to keep the PCM happy.
I guess with the LC-1, the voltage output for the narrowband signal is adjustable to the point that I can adjust the signal to the AF gauge so say 12:1 (or whatever you want) and above will read LEAN, 11:1 to 12:1 will ready STOICH (or safe) and below that will read rich. That's my current plan anyway.
I should know how well this works in a day or two.
________
Princess_Yud
Syclone Rob
Its all ABOOT the SYTY eh
Re: tuning and WB02
Sorry for digging up an old thread:...
Joylo, How is the LC-1 working out for you? I am researching which Wbo2 to look into and this seems like a good option!!
Rob
JayLo
Sir Boost-a-Lot
Re: tuning and WB02
Rob
Glad to have it back from the dust bin. :tup:
I am very impressed with the LC-1. I use the 0-1v signal for my AFR gauge and the 0-5v signal for the MegaSquirt I installed.
My gauge no longer jumps from full rich to full lean. It behaves exactly like one would want it to.
The MegaSquirt uses the wideband signal to control the AFR targets. I tuned a slightly rich idle (the truck seems to like it better) and then a slightly lean cruise AFR (for economy). Based on MAP signal, this gradually enriches to 11.5:1 up top. The LC-1 helps correct fuel by +/- 5% to achieve these AFR targets.
If you are just looking for AFR for datalogging and tuning purposes with a stock or Ultimate type chip, the software that comes with it works great.
In short, I'll be buying another one for my Cougar once I get it fuel injected. :)
________
Glass pipes cheap
Flyin Ryan
Re: tuning and WB02
Great to hear man.. thanks for giving your feed back after so long and thanks to Rob for digging this oldy up :)
93 TY 2185
Re: tuning and WB02
FYI on LC-1 and MagaSquirt.
This is from the Technology for Tuners Newsletter #11 from Innovate Motorsports.
Megasquirt Integration Note
High-impedance inputs, like those found in the current version Megasquirt fuel computer, can create problems with the LC-1 because the input caps act as dynamic shorts.
The easiest fix is to add a 470 Ohm resistor in series with the analog output of the LC-1.
JayLo
Sir Boost-a-Lot
Re: tuning and WB02
Thanks for the heads up. I don't know if that applies to the version3 PCB MegaSquirt but I will definately pass it on to Scott (the guy helping me with the install) to check.
________
LIVE SEX WEBSHOWS
