Tuning/Datalogging Programs/Hardware
willyson
trollin'
Basically, I want to tune my truck and see what it is doing while running.
From my understanding through search,
Datamaster - logs your ECM's information
Ostrich - allows you to tune your truck as an Emulated Chip
TunerPro - tuning software with Ostrich?
I plan on buying Datamaster and was wondering if I have already downloaded the software, do I just need to buy the cable? or the software bundle (in order to get a key)?
I have read about Ostrich and TunerPro, is it possible to tune with Datamaster or do I need to pick up the Ostrich along with a datamaster to tune?
Are these devices what I need? Or should I just stick with Datamaster?
SBNova
Re: Tuning/Datalogging Programs/Hardware
You really should read some recent posts, or search. I am too lazy to type right now, so I am just gonna quote myself from a recent thread;
For tuning software, check out Datamaster at TTSpowersystems.com or try my favorite which is Tunerpro RT. Tunerpro RT is a one stop program, that will let you scan the aldl stream for data as well as decipher the info on your current chip (you would need an eprom reader/burner to do so) and it will also edit the chip's info. If you get the real time hardware, like an Autoprom, Ostrich or Prominator, you can use Tunerpro RT to tune your truck in real time. It also has teh ability to input a signal from your wideband and datalog that too.
