Tuning for a good start
Quickstop [UK]
Combating adversyty.
How are people setting their trucks up to get the truck to fire fast and start strongly? I want it to fire up quickly, not on the third or fourth time round and I want it up to speed fast.
When I had problems with my injectors, it started like a dream!
Lean? Rich?
Far advanced or retarded?
Truck is set to +1 with the distributor, maybe +2.
Thanks!
Quickstop [UK]
Re: Tuning for a good start
So 40 views.
Are people generally happy with the time it takes their truck to get going? Or does nooone know how to make it better?
Davemc1963
93 Ty Owner
Mark,
My Ty starts first time! Only occaisionally does it have a solenoid 'click', but thats the starter. It doesn't have to crank more that a turn usually, a couple of turns at most before it starts, even after several weeks of not moving.
It however is a bit tatty and doesn't get cleaned never mind polished anything like yours does! Maybe you need to give it the Rat Rod look to make it start better. It could be that you have to treat it mean to get it to make you happy with it. It seems to work for me. :)
Flyin Ryan
hated cuz he drives fords
I would verify timing is correct and verify at the fuel rail that your holding good fuel pressure and it's not bleeding off right away (pump)
sytyguy
Moderated User
Mark, play with F54, F56, and F57. We have pretty mild temps here in the winter and quite hot temps in the summer, so my tables are askew from what you would have, but my F54 increments up about 1 point ever 12 degC in the cranking range (starting around 6 at freezing and ending about 10-11 at hot refire temps).
My F1 has some lower advance numbers at low map idle, but my cam/injectors respond better to that anyhow. I have no coolant correction that matters (some advance at extreme low temps and some extra retard at hot refire temps || atmospheric). For my truck, a little richer and less timing gets it to fire on the 1-2 crank.
Now watch that bitch not start when I go to leave.
Quickstop [UK]
Cheers Mike! I'll have a play.
I found all the crank constants and read somewhere that GM needs 8 reference pulses before it will fire and that might delay the start? More reading to be done for sure.
Ed Gasket
From England
For what its worth mine starts fine so long as you don't touch the gas until its fired up and then settled down. I was told that this is due to the Pitbull chip chucking too much fuel in under cranking if you do....know idea if that's right or not, but it's always worked for me....
Quickstop [UK]
It starts fine but I need to give it a bit of gas - not 100% like the cold start technique but I can't just start it with the key so I am wondering if it is too lean and when I crack the throttle it starts in a different cell or if it's too rich and needs more air.
Tooky mentioned that he tried tuning his to get a better start out of it so I wondered what could be done.
I'd like the newer, smaller and better 454 started but I need to find out the availability over here and the ever present cost implications!
If I find anything then I'll post up.
sytyguy
Moderated User
Mark, what's your base FP set at? FP can and will have an effect on startup. 60's don't seem to care as much, but 40s and 50s prefer a lower base FP (and consequently offset BPC) for easier starting. Food for thought.
Quickstop [UK]
I've been having FP dances with the truck. I thought my FP had failed a while back so ordered a new one when the truck wouldn't start. I filled it with new a tank of gas thinking it might have gone dry and it's been fine ever since. I set it for 42lbs without the vacuum, basically using IGN and the grey jumper and then adjusting the AFPR to 42lbs. With the engine running it was about 35lbd which I attributed to the vacuum from the engine? It was about -18in Hg at idle, 1000 rpm ish.
I'll keep an eye on the FP, cheers for the steer. 63# SIEMENS in there right now.
Thanks Mike! :D
