Tuning Lesson 101 How to get started
I am assuming you have some or all of the tools listed in the "what do I need" thread.
Open up tunerpro and select the definition files.
XDF defines where data is located in the chip
BIN is the data in the chip
ADS is how to read the ALDL cable
As I have suggested before for first timers get your feet wet playing with the idle. You will see some people like to run the idle rich for a smoother idle. I have found with careful tweaking and making sure the cells are correct I can get a smooth idle at 14.7 AFR. All personal preference try each way for yourself.
First thing to do once the bin is loaded is to turn off the closed loop and run open loop.
This is done to avoid the ECM changing things on you and allows you to get accurate info. In general my person preference is to tune open loop, get things dialed in as close as possible then turn on closed loop at the end. Sometimes I just leave them open also.
This is the setting which tells the ecm at what coolant temp to enable closed loop operation. It is in degrees C.
Set the enable temp to max coolant temp to disable CL operation.
Now open the dash (D icon on top of tunerpro)
This is a typical dash I use showing all the values you NEED. You can right click on any of them and select a different ALDL stream.
The 3 keys ones for fuel tuning are rpm, map, and AFR (wideband aka actual AFR, or stock o2 which is barely accurate).
Now open up the F29C table. This is the fueling VE table used for Closed throttle (less than 2%) and rpm's less than 1200.
Put the truck in park, observe at what MAP and RPM you are idling. Now look at the f29c table and find the cells that correspond to that. If setup properly tunerpro will even highlight those cells for you if you hit (Control + L) or the Red arrowed icon on top. (more on this later)
Now that you have figured out what cells are being accessed at idle, get a feel for the AFR or o2 volts. They will change some, but you should be able to tell about what they settle on. Lets assume in this example it average 12:1 AFR and we want 14.7.
12:1 is rich, so we need to remove fuel. The #'s in this table are volumetric efficiency.
If the ecm knows what size the engine is (it does), what rpm and air pressure is in the intake, it can calculate the amount of total air and hence how much fuel is needed. Engines though don't run at 100% efficiency. This table (along with others but ignore that for now) tells the ecm how efficient the engine is at THAT rpm and map. If you reduce the efficiency #, the ecm will calculate less air, hence put in less fuel. Higher efficiency # tells ECM more air, so it dumps more fuel.
Cliff notes: bigger VE # = more fuel, smaller VE # = less fuel.
So now adjust the VE # make it smaller. In this example move it 1 VE. Notice the AFR should change and get slightly leaner. Maybe you are at 12.3 now. Make another adjustment and try again.
Once you get park correct then try drive (but stopped). The load will change on motor, map value will get lower (less vacuum) and you will be at a slightly different spot in the table. See not that hard.
Once D is good go back to park, you will notice it is changed slightly. Go back and forth several times to get the AFR you want.
Reason for change: The ecm interpolates between cells. If it is in the middle of 2 cells it will take half of 1 cell and half of the other and average them. As it gets closer to a specific cell it uses less and less of the cells around it. This is why when you change 1 cell, it will affect the ones around it and engine conditions near it.
This is tuning. The same technique is used for fuel during cruising just with the F29 and not the F29C table.
I suggest new people the play in the F29C (closed throttle) table as you really can't do much damage aside from a fouled spark plug. Give it a shot, ask questions the pieces of the puzzle will start to click for you and your truck WILL start to run better, faster, etc. Then at some point you will look back and wonder why you didn't play sooner.
I will expand more, edit etc as I get time, people request new info, etc.
VermontTy
Support Our Troops
Re: Tuning Lesson 101 How to get started
Thanks for the quick dummy lesson Jeff. This is a big first step for all of us who don't really know much except looking at the pretty numbers on Datamaster....
SBNova
You make it sound like you can scan and emulate at the same time. Can you?? I cant with my autoprom- Mangus says its a glitch in $58, and he couldnt get it to work. I also don't have the patch to put the actual AF ratio into the aldl stream via a WB. At least I dont think I do.
I tune via BLMs mostly because I dont run open loop on my stock Ty. Anything you change the tune for outside of 14.7 (under most normal circumstances) will just be corrected back to 14.7 if you run closed loop.
If you dont have the ability to scan and emulate simultaneously, you will need to scan and take notes as to when you are doing what, then play it back and take notes on what to change and by how much. Make the changes by uploading/emulating or by burning it to a chip and log again.
With my suggested parts you can. The autoprom can't for our ecm's. (EDIT: It can now with code59) Has more to do with ALDL connection than anything.
You are correct you can scan, make correction then scan again.
You can do BLMs but BLM's are based off the stock o2 sensor, which once you go WB you will find is NOT accurate as you think, even at 14.7.
NecroWolf
lost marbles member
is there anything special needed to replace the stock O2 w/ a wideband O2?
SEL777
One of 101
Great info. I can't seem to even get my DM to read. I need to re-review how to get it set up properly so it will be useful.
Some people have a 2nd bung welded in.
When I use the LC-1 I just unscrew the stock and put the lc-1 in. The LC-1 has a narrow band output tied into stock o2, and the wideband gets tied into the F14 pin.
skwayb
NWSTP
SBNova,
Mark lives right up the road from me and is working on it. He is completely rewritting the ALDL portion of Tuner Pro to fix the problem. He is working on it. The problem is a timing issue. The 749 has a small window of opportunity to receive a command. The new ALDL code we will be able to change how long to wait to send a command, cascade commands together, etc. So this problem will get fixed.
What I ended up doing was getting an Ostrich for emulation and using my Autoprom for just doing ALDL (with it in the aldl mode). So right now my Autoprom is an expensive ALDL cable. Eventually I have will have second ecm in my Ty to control the 4l80e. So I figured I would use the autoprom with that ecm and just use the ostrich with the 749. I am not sure when the new version of TunerPro will come out, so I would just get the Moates Serial to USB adapter if you need it and his ALDL cable he sells. Believe me being able to emulate and see the ALDL stream is a great tool. Especially when testing the new code.
NecroWolf
lost marbles member
i like the idea of using one for both, wideband and narrow. so i just need to add a wire to f14 to the wideband output, and then tuner pro will read it or do i need a software patch to make it work?
Your current bin will need to be patched. Look for Dig's website (digware) he has the patches for each brand and instructions on how to patch your current bin.
When we release the new code this goes away, but for now you have to patch.
QUICK STORM
B.A.M.F. BMW Tech
so the g1 adapter goes in place of the stock memcal/eprom?
do you need to do anything different for high impedance injectors other than the ecm driver mod?
g1 goes between stock memcal and ecm, letting the ostrich or new chip be installed.
SBNova
Surprisingly, my wide band reads 14.7 when my commanded AF ratio is 14.7. I was amazed myself. I have not used my WB since I put in my new fuel pump. Before the pump I was way lean with audible knock. Now it runs fine, but I havent confirmed the AF ratio yet at WOT.
Black Knight
I Glow Therefore I am
Yeh thanx alot Jeff, this is really helpful for us newbies who would like to learn the black magic which is "TUNING"!!!
Keep um comin I try to soak up everything you write on this subject!!
