I am trying to understand this....
To switch to open loop, I only need to change 0x034A to maximum temp correct?
Next... where is the AFR vs. MAP table that I need to set to 14.7?
And once set to 14.7 what will the 02 sensor do?
At idle I assume that it is going to do its normal sway from low to high (100mV to 900mV),
then while driving...this is where I want to see what mV the 02 is putting out. ? What should I be looking for(600s, 700s, 800s)?
The VE table is RPM and MAP, so how will I know by watching the 02, which areas of the VE need to be leaned out or fattened up.... just look at datamaster and follow the 02 readings, looking at RPM and MAP?
What I'm looking to find out is... Once in open loop, the 02 is going to be my guide, as in 900s during cruise is too fat, so lean those areas....and how lean? 600-700?
Ok, once I feel I'm close go back to closed loop and set the BLM min/max to 128 and go off the int. ? If that is true how is the BLM min/max set?
I found 0x0355 and 0x0356, but they looked like they were different values....such as 1.17 for MAX BLM, and .82 for MIN BLM on stock bin. I see that at the 1.17 and .82 are values, and the int looked closer to normal and were in units.... 80 min, 218 max.
TIA.
Scott
The open loop AFR correction vs. MAP and AFR correction vs. coolant temp
tables are only used in open-loop (no O2 sensor feedback). These 'corrections'
are used until the engine and O2 warm up enough to go closed loop.
Once in closed-loop, the desired afr is set to 14.7 (this is used in the bpw
calc).
If starting to tune in open-loop (no O2), then set the afr vs. map table to the
14.7 value. You can then look at the O2 sensor and make the gross adjustments
required. Once close, go to closed-loop (O2 feedback), set the blm min/max
to 128, and use the int to tune.
Open-loop tuning is only needed when you are starting with an engine that
is radically different from anything gm has produced. I've used it on
occasion in a couple of areas of the ve table.
TIA.
Scott
