Raist103
i have been trying to tune up the stock 93 ty. my o2's are 930-960 across the board but i also have knock from the time i hit 7-8psi max i ever saw was 6 and normal was 3-4. boost is all over the place from 9-14.7. i am thinking i should start by putting a afpr on and turning the fuel down as i think i am way rich, i thought the last time i was playing with a stock ty o2s should be 780-820's. i know to truly tune you need a wideband and such. i am just trying to get it running better. i dont plan to keep it but want it running right for the next owner. shifts are at 4200 1-2, 4100 2-3, and 4200 at 93mph when i got out of it. tps is low about 80-85% and volts at wot never go above 13.2 and no lower then 12.8 which i think is a little low. inj dc is 70-90 on avg and 102 at one point at 88mph. as far as i know the ty is 100% stock except for a muffler and cat delete. engine temps are a little high as well maxing out at 204 and starting at 199-200 area iat start at 150 end at 175.
thanks in advance
don
thanks in advance
don
