Re: tuning the f29c table
cvcsmkr said:
okay.
my truck is idling in park 775-825, sound high?
in OD it stays about 675-725.
i was going through the idle tables, and i didnt see where you set the idle rpm?
so no matter P or OD, load or No load i should shoot for 14.7 and or lower for cleaner idle. right?
i had my fuel press up to about 43, this is rebuilt motor with typ rods, valves, pistons.
it does have a 412 cam, pte44, 50#, 255 pump.
can someone give me a range of what my fuel press should be.
i am wondering if i should tune wot first to get my fuel press right, and then go back thru everything, i dont want to tune f29, f29c, and when i get to WOT tables i have to change fuel press. does that make sense?
There will be a couple of main tables to control idle rpm:
- Idle vs Coolant Temp (in gear)
- Idle vs Coolant Temp (in P/N)
- Idle vs Battery Voltage
You'll want to get the idle happy (no stumbles, pushing through brakes, etc....700-800 rpm and 13.5:1 or so will do for now) with it in gear and in P/N. Next you want to make sure that there is as little as possible difference when shifting from P/N to drive/reverse. You can't just go in and match the values in the top two tables, because there is a load difference in between those two conditions. Every truck is different, but I usually start with a 100 rpm difference and tune from there. (I tuned the '92 Sy idle so heavily that the only way to know it went from N to D was to look at the shifter.)
* Remember to put the idle through it's paces (come to stop from speed, test with headlights on and turn steering wheel at idle, etc....)
If you have electric fans, you'll be glad the idle vs batt voltage table is there as it has cured any stumble from high amp fans on any truck I've worked on. I usually set the idle for the lower voltages (10v-13v) higher than desired idle in an incrementing form from (50 rpm to 150 rpm), but keep the 14v+ value near desired idle.
After getting a consistent idle that you like (easy to hold still, doesn't try to die at stoplights, etc....), you can start trying to lean out the mixture to get your AFR up near stoich. Don't get obsessed with it, but try to get near 14.0-14.5:1 so your not burning people's eyes when you crank the truck up. If you spend a fair amount of time in town (sitting at lights) then you can gain some considerable economy by get idle AFR right.
FWIW, I have my truck running 14.5:1 at idle in P/N and 14.0:1 in gear (800 rpm idle) with a 412 cam, 50#ers, L35s, 9/11 TC, etc.... so you should have no problem as our builds are similar (my FP is @ 42 psi and I have tons of fueling headroom.)
Hood
