tuning tools
Ryda85
Senior Member
hey guys, i am pretty new here and am planning my syclone build. just curious what tools everyone uses for tuning....it seems that a scan tool such as datamaster is used. is a wideband o2 necessary? is there a kit that has both of these in one? i have never tuned an efi car. before this it was all carbed chevys.
also, i have a laptop that could be used in the truck....if that helps at all.....thanks guys
#2875
built, not bought
i use turbolink. used WITH a dyno you can tune properly. a scan tool by itself may help you identify problems. the dyno shop has a wide band o2 that they will put in place of yours during the tuning process. i'd do a vacuum check too. i'd also modify a 9/16 wrench so you can quickly make timing adjustments and an afpr is a MUST!!!!!!!!!
