Tunner Pro RT set up help?
NeedaSY
Go Ahead N Go
bought cables to run the RT program and can only get as far as connecting but can not find hardware or Emulating need help to get started to run realtime displays and can make a run to douload my data.
Thanks,
NeedaSY
Go Ahead N Go
Re: Tunner Pro RT set up help?
QUICK STORM said:
did you get the ostrich, g1, and a wideband
I have the ALDL to USB converter and OBD-1 connector. From craig Moates. And some CD he gave me. My brothers laptop.
nallj92
all your gonna be able to do with those cables are record data, you cannot change or load bins or anything.
you need a ostrich and G1 adapter to do that.
there is a driver folder on his cd to get the aldl connected, read the readme file
NeedaSY
Go Ahead N Go
I got ya i have got that far i filled in all the blanks in the left side of the screen like number of cylinders etc. and it red my computer where do i get the rest of the stuff i need from link whould help.
Thanks guys big help.
MRKING
New Parts for Old Trucks
You need to load the correct .xdf and .ads file . They have the correct info already calibrated for your engine . Check yesterdays posts , I believe new versions came out .
NeedaSY
Go Ahead N Go
whats the switch on the ALDL/USB converter do.With my truck running i switched it one way and it cause my idle to go up and the middle position was normal idle and the last position was choppy idle and made my check engine light flash?
MRKING
Some Obd1 systems require a 10k resistor placed between pins m+b to put in diagnosis mode and that switch does it . Our trucks dont require it , and thats why it makes the truck act funny .
SBNova
You only need the ADS file. By filling in the cyl size and all that stuff on the left, it doesnt do anything. That whole section of the screen is for editing the prom, which you cant currently do with your hardware. You just need to select the correct ADS file using the icon at the top that resembles a piece of paper, the hit the connect button, and select the "D" for dashboard when its connected. Try that....
