Tunning place
JoveDios
1993 Gmc Typhoon #0627
Ok I think my truck is due for a tunning and get dialed in right
I live in sylmar, ca
Anyone know a good shop or place or someone that can do a good job
JoveDios
Re: Tunning place
And I'm not sure if I have a chip or if I need one I need someone to help me look thrue n really set me in the right direction if anyone is near me or anyone knows a shop near by Id sure appreciate it
Logan
Re: Tunning place
Only way to verify what chip you have is to pull the ECM. It is located behind the dash and is accessible from the front passenger floor board. Do a little searching and you will find some threads on it. It takes some finesse to get it in and out but once you do it you will understand. After that, you can easily determine what chip you have. If you are running a stock truck with a pre-programmed chip (i.e. not code59) then there isn't a lot of tuning that can be done. Hood can burn chips, Turbo Tweak offers a very user friendly set up from what I have seen (I am going with this one) and then there is always Code59.
A lot of guys live and die by Code59 but it does require you to gain some understanding about that world and can be a little intimidating at first. I am running it currently but am going with the Turbo Tweak chip because it seems to be less complicated.
Best of luck with everything.
berzerker
wookie
Re: Tunning place
you could always take it to rpm located in Chatsworth CA. big syty builders / tuners . look in vendors section .
