Tunning the stock ECM
It's just a six
Super Member
Re: Tunning the stock ECM
turbodig said:
I will kinda break from one of the "commonly held truths" in this case...
If you're already fast with a Pitbull, all you might need to do is tune it a bit. (vs. switch to 3bar) You will need to have it patched for wide-band, or barring that, pick up an Innovate LMA-3/LC-1 and datalog on the side.
You *can* work around some of the limitations of the 2 bar map, and if your truck likes what it's getting so far, might just be that you really only need to tweak the timing a bit, and pull out some fuel on the low end. (Pitbull was notoriously fat in the launch area).
It *is* possible to tune/improve 2 bar chips. However, I will say that if you're looking for "outer limits" fast, at some point you won't be able to compete with the more advanced cals.
Thanks Dig,
I have not had a Pitbull in my truck for @ least two years?
I am running an old STG 10-1 chip w/a three bar map sensor.
I think it is as fast as my old pitbill chip maybe a little better on the top end,(it's really close)
I run an LM1 from Innovate for my A/F mixtures(Ghetto tunning)
Since I do not know how to program.I adjust timing, fuel pressure ,& watch KR
It seems nobody here in Cali does any ECU tunning??? What a shame.
Also,, thanks people who PM'd me privately for answering my question,(who would they recommend to send there Sy/Ty to for some ECM tunning),( seems some people can't give a straight answer, being sarcastic & so-on,, trying to change my question around to their liking.)
Again thanks for the private reply's
turbodig
It's just a six said:
Thanks Dig,
I'm quite surprised that there aren't more tuners in your area... Cali has a higher % of trucks than anyplace else.
If you're already 3 bar, and you've got the wide-band, you have most of the stuff you need already. That should help whomever you get to tune a bunch.
This does bring up a good point, though.... we should really sticky a (qualified) "tuners by region" post...
Later,
