Turbo Blanket SOLD
1BADV6
This is a new turbo blanket made to fit the stock syty turbo. It is a tight fit at the wastegate rod but fits the housing well. I have also used these on PTE syty housings but it is a little on the small side and does not cover the entire housing where it bolts to the manifold. Asking $100 plus shipping from 18929. SOLD
thanks,
killa66cam
RIDIN DIRTY
Re: Turbo Blanket
Re: Turbo Blanket
thanks,
How well would it fit on a 20g? Have a stock turbo right now, but the next one will be a 20g.
Cam
1BADV6
Re: Turbo Blanket
Re: Turbo Blanket
Cam
Should fit fine, the outside dimension of the 20G exhaust housing is basically the same as the stock turbo.
Dave
killa66cam
RIDIN DIRTY
Re: Turbo Blanket
Re: Turbo Blanket
What about a 60 series turbo? Was wondering how much size difference there would be compared to stock/20g? Asking because that is the turbo you recommended for use with the 50# injectors and chip that you are selling...that I am also interested in. Thanks.
Cam
1BADV6
Re: Turbo Blanket
Re: Turbo Blanket
Cam
A "60 series" turbo would have a PTE SyTy exhaust housing like I refer to in the ad.
"I have also used these on PTE syty housings but it is a little on the small side and does not cover the entire housing where it bolts to the manifold".
thanks,
