turbo boost...only 10psi??
flintdawg
i was wondering why my turbo will only boost up to 10psi....i am taking my readings from an aftermarket autometer guage....but i am going to hook my laptop up sometime this weekend...should i adjust my wastegate...and which way???
nick041881
check the vacuum lines on your wastegate selenoid. 10 psi is usually a leak on the selenoid vacuum lines. did it ever used to go higher? if this is just a recent issue then turning the rod wont fix it..its most likely a leak somewhere.
peace,
nick
SeattleSy#1255
Category 5 Conservative
I agree, check your vacuum lines and perhaps your selanoid has gone bad. You getting base boost--pretty common problem if you vacuum lines have not been replaced...they get weak and brittle, thus breaking or leaking. I wouldn't adjust the WG yet.
SY756
If you can't find any leaks on the lines check out the wires going to the solenoid. I had that happen on my truck, one of the wires had rubbed completely in two under the upper ic. And, I agree with Jeff, it also could the the solenoid itself. I think I have one laying around if you need one.
flintdawg
i actually just recently had my whole motor rebuilt....everything runs great and now that i have almost 4 thousand miles on it i am starting to tune everything in it....and i was noticing that when i go WOT it doesnt go past 10spi....but i remember when i put ian's vac kit on it....that the solenoid on the turbo looked like it had been superglued back together(the little nipple piece anyway)....but it seemed to work fine....but i will double check my vac lines and hook my dm up to it and do a run later tonight.....how much does a new solenoid cost? or should i try to adjust the wastegate first? any help would be great.....thanks
SeattleSy#1255
i'd leave the WG for now...that is most likely not your problem...When you put on the new vacuum lines did you make sure the check valves went the right direction? There could be a leak still, you must look closely. A new solenoid is about $20---I have one if you want it. Its used but i'll sell it to ya cheap, yet it may be faster to just go but one at a local dealership. I wouldn't even relplace that yet, those vacuum lines can cause a major problem. If the solenoid was glued, then it could be busted..so maybe it it that...i'm not sure...
