Richard Le
Can a bad turbo burn oil? I'm losing quite a bit of oil in a short amount of time, and I'm not sure where the oil is going. There are no external leaks, and I have brand new valve stem seals and valve guides. Compression check turned out fine. There is no blue smoke on start-up. There is no blue smoke on acceleration or deceleration. Sometimes if I rev the motor up, I get an oily substance coming out of the tailpipe.
I'm using TRW forged aluminum pistons. Any ideas?
