turbo coolant feed line
SeattleSy#1255
Category 5 Conservative
I'm trying to get the turbo coolant feed line out from the bottom of the block but there is very little if any room to get up in there...what is the best way to get this thing out.
SY2932
Administrator
I'm not gonna BS ya, it's a ROYAL PITA. I got the "pleasure" of removing it and plugging it on two Pennsyltucky trucks a few years ago... I used a combination wrench on both to get the job done. It's a turn the fitting a 16th of a turn and then turn the wrench over so you can get another 16th of a turn affair :-? . Be sure to hose the line where it gos into the fitting with some penetrating oil. That way, you are trying to turn *just* the fitting and NOT the fitting AND the line if they are frozen together.
Get ready to get a lime green shower because even if you drain the radiator, there is *plenty* of coolant still left in the block to hose ya. IIRC, the starter is in close proximity to the line. Disconnect the battery so that you don't try to arc weld the wrench to it if you inadvertently make contact. Take your time because you DON'T want to round off that fitting.
SeattleSy#1255
thanks mike...thats what I needed to know, if there was an easy way and i was just missing it or if it really is the PITA that it has proven to be.
socalblue
Re: turbo coolant feed line
What size line should I use for both (in/out) the turbo coolant lines if I am going the steel braided way?
And while we're talking steel braided lines, can someone also tell me what size lines I should use for both the oil lines to the turbo as well?
I also need to get the flange for the oil return line, I know some vendors sell them but they look like they are for aftermarket turbos, will any of them fit stock Mitsu turbos?
And to get back to this thread, yes that was a PITA to get out...thanks in advance!!!
