brock1949
Its alive!!!
Well here is the break down, I have 94 s10 that i've had supercharged for some time now and i finaly got sick of messing with belts and alignment problems. I started road racing it following a car club around with some freinds of mine and last week i went through 5 belts in 4 days. I was getting tired of it, now i have to pull my heads back off tommorow and check everything out because i've got a leaking head gasket so its time for change..
I have been running around 4-6lbs of boost on the supercharged just to take it easy on the belts.
I am picking up a set of sy ty manifolds this weekend from a memeber on this forum and probably his old turbo also.
My question is that if i'm only going to run 8-10 lbs and probably nothing over 12-14 on this motor maybe later on a stronger motor i'll do 14-18 or so..
But for now i'm just worried about running 8-10 psi and having this truck up and running in the next 2 weeks or so,..
Is the stock turbo the TD06-17c the most efficent for my application? I am getting the turbo for a pretty good price as long as its in decent shape,.. But should i have it rebuilt ? its got about 75k on it, or should i have it rebuilt with the GT30 center? i have a freind that went that direction..
Just wondering some input from the pro's on if this turbo is going to spool fast, be efficent and worth building the custom downpipe etc etc to support this setup in my truck.
Also whats a good headgasket for my setup? i tried ROL's and thats what just blew on me with 5lbs of boost and 5900 rpm... with no detonation and spraying meth... on a 11.5-12.1 AF
Thanks everyone!
Thanks everyone!
