Turbo making a weird sound
2500avalanche
Well-known member
I am in the process of over-hauling my ty I just purchased. In my driveway, I did a couple of boost launches, and the turbo is making a grinding sound, I am sure it need rebuilt. ANy reputable shops or is it something I can do myself with a rebuild kit? I am sure the bearings are gone.
Re: Turbo making a weird sound
I would guess your turbo grind noises are due to compressor wheel hitting the housing rather than the bearings. The most common SyTy stock Turbo failure is from pieces of the crossover tube being chewed up by the compressor wheel.
Nitrous
I agree with Sy#266, mine is hitting and it looks like part of the air tube might have gone through it. Pull the elbow and look at the compressor inlet with a mirror. You can also feel for axial movement.
Luke
Fish sticks SUCK !!!
while your in there you might as well _____ and_______- and _________ and__________-and__________
:haha:
2500avalanche
Well-known member
The compresor wheel? I am new to the typhoon, and I see the turbo, but would the compressor wheel hitting the housing be inside the turbo? I know it sounds stupid, but I am trying to understand this motor...
SikVSix
yep, take the intake elbow off the front of the turbo and look inside at the compressor wheel. grab it and move side to side, its probably touching the sides and look for bent fins where something has gone through it.
for movement about 1mm is ok side to side. you want no movement in/out. HTH.
2500avalanche
Well-known member
Do they have rebuild kits, or is this something I will have to purchase an entire new stock turbo?
2500avalanche
Well-known member
By the way, your advice is great. I will try to look at it later today!
If the housing is chewed up, I think you have have it rebuilt with a bigger compressor wheel. I am no expert on rebuild turbo's though.
