Turbo Modifications---
alwayscode390
pppssssshhhhhtttttttttttt
I just got a PTE 63 big shaft turbo, and wasnt sure if I should modify it in any way before I get it installed. I have heard of "dual ball bearings" .... who does good work? What should I get done to my new turbo....or should I leave it stock, THANKS ---
James Thomas
"NO CLASS"
Re: Turbo Modifications---
Port match the turbo to your ex. manifold and Jet Hot coat the turbin housing and down pipe.
_________
James
HotRudyRod
While port matchin the turbo you might also wanna port the WG's bend too, make the bend as "soft" as possible so you get better boost control. I also made some kind of directional fin on the little rib you'll find on the exhaust's charcoal mark to direct as much exhaust energy to the fins and away from the WG's bend.
