turbo nut
VinPecora
i lost a nut off my turbo!!! Anyone have an extra one laying around or can tell me a part # or a nut size so i can get one from home depot or sears hardware. I dont want to try fitting nuts and stripping the bolt. thanks guys
tealty
Re: turbo nut
I'd try to get a stock replacement. its a whacky thread, i think metric if i remember right. and if you match the thread pitch/dia with a nut at the hardware store, chances are the hex head is gonna be big like 19mm.
later
jordan
Ian Turgeon
Cascading Inspiration
Re: turbo nut
it would help to know what nut, theres a couple on there....
If its the band clamp, just take the bolt to the store (LOWES is good) and match the threads with a LOCK NUT. dont drive it w/o that nut/bolt... could end in a bad day
tealty
Re: turbo nut
If the nut you are talking about is the one holding the actual housing on the turbo, then you could probably find that one at the hardware store. I was talking about the dp to turbo nuts.
later
Jordan
Loeryder
Re: turbo nut
I think he means the studs going to the DP.
I took the studs out and replaced them with allen head stainless bolts.
Makes getting the turbo in and out a lot easier not having to pull the DP back an inch for clearance of the studs.
VinPecora
Re: turbo nut
im talkig about the DP to turbo nuts, the turbo has studs which hold the turbo, i need one of these bolts....anyone have one?
