Turbo oil / coolant return
Quickstop [UK]
Combating adversyty.
Hey all,
Today I was hoping to replace the hoses to the turbo with braided hose but I am having serious problems....
On the coolant return hose that goes to an orange rubber bit then pipe again (why oh why?) how do I get to the bolts? I am thinking about taking out the starter.....
Right next to the coolant return is the oil return with a 90 degree bend. It looks as though the bit attached to the pipe is a separate fitting. Is this the case. or does the whole 90 have to come out? If so, how can I make access easier?
Thanks guys,
Mark
Quickstop [UK]
Re: Turbo oil / coolant return
Update:
I took out the starter - some people on here made out it was a real PITA but mine was sweet. Off in about 10 minutes then started working on the two hoses. 2 electrical connections (13mm and 8mm) then two bolts (14mm) then push forward and up then rotate then pull back down and Robert is your father's brother.
Once the starter is gone, the first one (coolant) is not too bad. 19mm and a 17mm on mine (no guarantee seeing as it was maintained in Saudi Arabia - say no more). That came out ok. Bucket came in handy as well!
The next one, the 90 degree union was more of a pain. I couldn't get ot off as i think it is mounted either side of the oil sump with a bolt, not actually into a bung or anything. I decided to go for the adaptor (3/8 NPT - hose end). I had to use a blow torch and WD40 on it. Eventually it gave. WTF it was a 7/8 spanner I have no idea. I wish GM had stuck to either metric or imperial. Oh well.
Now those two parts are off, its braided hose installation time tomorrow and then the exhaust rebuild.
