turbo oil line ???
1blkc4
Looks like my turbo oil lines are leaking near the oil pan what are my options ?Could I keep the metal line and use silicone hose and clamps in place of the rubber ? These look like a real pita any sugestions ?
atkonkler
Is this your bush?
Re: turbo oil line ???
I bought a braided line from rpm...Easy to install with handtools....great product also.....
TrendSetter
Organ donor in training
get a 1/8" npt to -4an steel brake fitting from summit, and a -4an pre made braided brake line long enough to reach your turbo. that will last longer than your truck.
2500avalanche
Well-known member
I was actually just having to do this. I hat the hard line to the rubber line, and then back to the hard line. This will work better. Thanks. I hate that little drip I get from it
1blkc4
what size is the rubber hose I might just replace the hose with silicon and clamps .
Slyclone
Well-known member
The drain must be 10an. So I think that's like 5/8 hose.
I'm pretty sure it has to be enough for proper draining or you will have a restriction or back up.
You can just replace the hose which may be the problem.. But who's to say it won't leak or drip again?
What I found with mine was that something had actually hit the rubber hose against the metal barb and it was nicked. I blame it on the guy who handled the build and he acted like a @$$wipe so I let it be. I saved the small hose which is a reminder to me...
I bought a roll of 10an hose and a box of various ends and just made my own new hose that will never leak with the threaded and conical seating surface.
This is what I saw when I began to freak out.. But here is a little run through the mill of what I ended up doing.
I bought the larger L or 90 piece thinking it was correct but I ended up needing the strait fitting to adapt into the oil pan bulk head..
Some of the other materials I used, 45* 10AN fitting, Strait 10AN fitting, Kinugaguawa Nickle plated adapter with another converter to 10AN.
Slyclone
Well-known member
The orange one is a coolant return which returns coolant back into the block. The coolant feed passes horizontal with a J style feed off front intake manifold.
Identify them as this:
