Turbo oil return line diameter
VermontTy
Support Our Troops
Re: Turbo oil return line diameter
The fittings on the end of the rubber, and on the end of the fitting on the pan are 1/2" NPT. Not sure what the ID of the rubber, or the fittings are.
skata
it is 5/8".
sometimes, you might get away with just removing the stock clamps and putting new clamps on the stock hose, since it's a pita to change the hose.
leadfoot
Does anyone make a stainless braided kit for this line??
Has anyone retroed a stainless braided hose for this?
VermontTy
Support Our Troops
Yeah, RPM sells them with their PTE turbo kits, and they sell them for Garret turbos individually. Dunno if there is one out there for the stock mitsu turbo or not. It'd be easy enough to get a lentgh of -10AN hose with a 1/2" NPT end to thread onto the pan fitting, then just cut the stock pipe near the flange with a pipe cutter, slip the braided over and hose clamp it, or if you really wanted, use a compression fitting to affix the pipe.
http://www.raceprovenmotors.com/cart/product_info.php?cPath=46_57&products_id=424http://www.raceprovenmotors.com/cart/product_info.php?cPath=46_57&products_id=424
Jimmy
Banned
I ordered one from Mike @RPM yesterday for my Garret. :tup:
hatrik8
I'm also having the leak problem with the return line from the turbo. Did anyone find out about a braided stock replacement? I've seen the non stock turbo at rpm.
Flyin Ryan
hated cuz he drives fords
No one makes a braided kit, you'l have to make your own if you desire. It would be cool if someone did make a kit though for the stock turbo there's still alot of stock turbo users out there.
