Turbo Oil return line Please help
hatrik8
I need to replace the turbo oil return line on my truck. What hose do I need to use? Is there anything special about it? I saw there are braided lines from rpm, but not for the stock turbo. I did a search, but didn't find any good info. TIA
VermontTy
Support Our Troops
Re: Turbo Oil return line Please help
Toss up a WTB post...I'm sure someone has one; there's nothing too special about it. Did yours spring a leak or something? The hose isn't anything special; just your normal oil-resistant hose. If you still have the metal piece coming off the turbo, you can replumb it down to the pan, just make sure its oil resistant hose, becuase if it isn't, it'll swell up and get real weak. Might want to PM Kevin "blk97ta"; he seems to have knick-knacky stuff like that.
hatrik8
Mine is leaking. I think it is from being over tightened on one end and it cracked a little. I'd like to get a braided replacement, but can't find one. Nice rabbit by the way. :lol:
hatrik8
Is it a stainless braided stock replacment? or is it the stock hose?
VermontTy
Support Our Troops
haha...I chuckled when I saw that .gif, and had to put it up. If you want braided, I don't know if this fitting will work on a stock turbo or not (prolly not
EDIT
woops..hit submit. Don't know if that fitting will work or not, but if it does, you can just buy a length of -8AN hose, get a pair of 1/2" NPT male ends, and make it go. If your metal near the turbo is good, make a new gasket, use a pipe cutter to cut back the metal line, and clamp on a piece of stainess to the metal you left on that end. There shouldn't be too much pressure there.
Loeryder
E at turbotime.us sells a braided kit that fits stock turbos.
gonna order mine as soon as E pms me back.
Flyin Ryan
hated cuz he drives fords
What kind of price is he charging for this?
blk97ta
if you need the return line that goes down to the pan i have one ! $20 and meet a mcd's ? :tup:
ranger
I'll take it for $20.00 if you still have it. Please PM me.
Thanks,
Craig Stangohr
Aiken, SC
