Turbo Question
TYTILIDIE
METH HEAD
This may be a rerarted question but, I am starting to mock up plans for my A2A for the spring and a few other things and Im wondering about the angle of the turbo. Can it be altered to point a different direction or do you have to get a new one and order it that way? If it can be done, how do you do it? I noticed a clamp of some sort that looks very much like it holding it together. Any help would be appreciated.
Mike
kwick6
Just loosen the six or so bolts on the compressor housing enough and it will turn, then just tighten it back up.
jwaller
Evil Genius/SyTy Guru
you can move the turbo as described if you have a pte or garette style turbo.
if you have a stock turbo it has an alignment pin between the center section and the exhaust housing that must be broken to allow you to clock it.
or you can loosen the very large C clip that holds the compressor cover to the center section if you just want to reclock the compressor cover.
TYTILIDIE
METH HEAD
Yeah I have the stock turbo. and all I want to do is "clock" it. Is this clamp hard to get off and will I need to buy another one? What about the alignment pin, will that be trash?
Mike
Boosted
Bump..
I am interested as well.
I heard that you have to grind off some dowel pin?
Since I have not had mine off will someone explain a little more in layman's terms?
Pictures?
jwaller
you can see on the rusty pic the aligmnet pin at the 6oclock position that needs to be knocked off so that the center section can be rotated. yuo can do this with a hammer and flat head screwriver
the pic of the new turbo you can see the clamp that holds the comp cover to the center section. you can also see the location of where the aligmnet pin fits into the center section.
