Turbo Question
Richard Le
Let's say one turbo is rated at 550 cfm and another is rated at 800 cfm. Would you still get the same amount of air from the larger turbo at a given boost pressure, or would you get more air volume?
smeagol
That depends on the given boost pressure, and what motor it is on. A motor with higher volumetric efficiency will swallow up all the air the turbo can produce, providing for less resistance, and therefore less boost than a similar motor with lower VE and the same turbo.
Brian G
