All all the mistubishi td06 turbos the same? I found one new pretty cheap, the mounting flanges look correct as do the oil drain and coolant lines. Are our turbos syty specific?
Thanks guys
pics need to be bigger but it looks like you might be able to use the center and front in our trucks but the turbine housing connection to the DP is very different.
